@sapch Normal vector is always changing in curved beam but at straight beam it remains same..As compass direction changes at when you move on curved beam but in case of Straight line it remain same....
Thank you very much for your reply. In 3D View, the curved beam cannot display the compass mark?
@sapch Same issue it will not show. as i stated above..
Thank you for your answer!"Tekla" can be used to indicate the curvature of the beam. Did I use it incorrectly?See the results of Tekla:
@sapch the symbol you are showing is the starting point of member when you modeled it... It is not the compass mark...
So how do you get this sign of the arc beam to show up on the 3D view?
