Crash in selected assembly drawing process
StefanoPasquini6790
Advisor Advisor
StefanoPasquini6790
Dear forum members and adsk support,
When I launch a drawing process for selected assembly, I have often this kind of error message, with relative Advance Steel crash:
I have also a lot of crashes with simply ACAD move command, is there someone that can help me with this issues????
Thanks a lot,
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
múinteoir
Do you have Hotfix 1 installed for AS2017? There was a bug that caused crashs when creating assemblies with end plates.
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
StefanoPasquini6790
Yes I have, I also have acad 2017.1 release, I tried also to uninstall it, but the crashes are always the same....even for simply acad command...
PasProStudio
StefanoPasquini6790
Hello????
Is there nobody with the same error???? I've seen in the forum a similar issue in ADSK Plant...
I need a solution, I'm not able to manage my model differently.
Cheers
PasProStudio
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi StefanoPasquini6790
Thank you for using Advance Steel forum.
I think I would need some additional information from you to understand what is going on.
You say that this error occurs when start a drawing process.
First question:
- Does the error occurs for any project ? Or only for your current / a specific project ?
Then, please let me know if you have other AutoCAD 2017 verticals installed on your system - Plant 3D, Civil 3D ...
And one suggestion / test: please set the DEMANDLOAD to 2. Then start a new AS session and try again to start the drawing process.
I will wait for your reply with the additional info and test results
Best regards,
Emy
Emy Nestor
StefanoPasquini6790
Hi Emanuel.Nestor and thank you for your answer.
Answering to your questions:
1)   Does the error occurs for any project? YES but not everytime that I run the drawing process
2) let me know if you have other AutoCAD 2017 verticals installed on your system - Plant 3D, Civil 3D: No other AutoCAD 2017 verticals installed.
Anyway, I've set the DEMANDLOAD to the value 2, and the process it works correctly, but I miss the logo in the prototype file so, I set once more the DEMANDLOAD to 3 and now it seems that works properly.
Thank you again for your support, I will update you about this topic.
Cheers
PasProStudio
