CONNECTION
CONNECTION
CONNECTION
Dear All,
My query is that why when amending/updating a connection , nothing happen that is visual change but the parameter form the properties changed ?? is there a hotfix to install
crydee-AG2
Please check the bottom of the Joint Proprties dialog box and make sure you have "Automatic" ticked next to the Update Now button. If this has become unticked that is why the joint is not updating.
For larger joints like stairs and railings it may be helpful to adjust a number of parameters before the joint updates (by clicking the Update Now button) so you can stop the automatic update for this. Normally howeer you want Automatic turned on.
Aleck Giles,
LinkedIn
Autodesk Certified Instructor - Gold
