Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Contour Mark in NC for Assembly
2 REPLIES 2
705 Views, 2 Replies
Does anyone know how to set the NC for mark the principal profile for assembly?
Mark all the contour; mark only the reference points and mark the name? (Check image P1 and P2).
Thanks a lot!
2 REPLIES 2
haedicu
go in Management Tool to defaults and filter for "scrib" - you will find a few defaults, where you can define complete / end lines, distance, set contour marking on/off.
You have to set the NC based on main part numbers too in NC settings.
If you create the nc-files afterwards - they should contain the contour marking information. You can check this easily in the nc-dxf files (preview under document management).
best regards
Udo
in reply to: haedicu
It worked! Thank you a lot!
Technology Administrators
