Is the following connection available as a macro?
It is two beams with end plates bolting through another plate (shaded grey).
Hi Harry,
Can't find a single macro to do it all but you can use a combination of two.
Start with 'Post double beam' & follow it up with 'Double sided end plate' to connect the two beams to the vertical plate.
hope this helps
Geoff.
Thanks GMDS.
I tried it with a plate but the macro doesn't let me select it - it wants a beam.
I then tried a flat bar instead of a plate, and it almost worked, but returned an 'invalid pointer'.
