Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Connecting RHS to I- section
3 REPLIES 3
andreasmand92
893 Views, 3 Replies
Is there any quick connections that gives me this type of connection, where I have RHS tubes connected to I-beam stiffeners, as shown on the picture? I have been doing this manually. I cannot get a custom connection to work properly - I still have to do a lot of editing if profile sizes or rafter angles change so I find it easier to manually create the connection each time.
Just curious if anyone knows a faster way of doing this.
3 REPLIES 3
múinteoir
in reply to: andreasmand92
I dont think there will be a quicker way other than a custom connection. They are tricky to master and get them dynamic but with some time and testing it all looks possible.
Jonathan Hand
Technology Manager - Symetri Tech
 autodesk-expert-elite-member-logo-1line-rgb-black
twitterNaviate
Hi, you can use the "Tube connection with sandwich plates" connection will give you what you need, there are a lot of variables in that connection so you need to know what to turn off etc.
If you can attach your current model i can take the setting out / dimensions from it and then record what to change etc within the joint
Rob Merriman, AEC Technical Lead, Graitec
Hey! Sorry for my late response.
You are right, I managed to use that connection to get all required plates, but then I deleted the joint box and manually edited the stiffener to fit the I-beam.
I know i could edit the stiffener parameters to fit the beam on the joint properties and then apply corner cuts but i find it takes less time doing it manually.
I wish there was a command to extend the stiffener to fit the rafter without deleting the joint box.
