Is there any quick connections that gives me this type of connection, where I have RHS tubes connected to I-beam stiffeners, as shown on the picture? I have been doing this manually. I cannot get a custom connection to work properly - I still have to do a lot of editing if profile sizes or rafter angles change so I find it easier to manually create the connection each time.
Just curious if anyone knows a faster way of doing this.
Hi, you can use the "Tube connection with sandwich plates" connection will give you what you need, there are a lot of variables in that connection so you need to know what to turn off etc.
If you can attach your current model i can take the setting out / dimensions from it and then record what to change etc within the joint
Rob Merriman, AEC Technical Lead, Graitec
Hey! Sorry for my late response.
You are right, I managed to use that connection to get all required plates, but then I deleted the joint box and manually edited the stiffener to fit the I-beam.
I know i could edit the stiffener parameters to fit the beam on the joint properties and then apply corner cuts but i find it takes less time doing it manually.
I wish there was a command to extend the stiffener to fit the rafter without deleting the joint box.
