Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Configuration dimension - DSM
2 REPLIES 2
348 Views, 2 Replies
Hi all.
They could help me in configuring DSM,
I configure in such a way that the bounded ones are shown as the drawing, but I can not add the lower bounded.
Thank you.
Best regards.
Atte. Cristian N.
Configuration 1
Configuration 2
In this case reorder and add the 1.
But the upper bound disappears and the lower one appears
Hi all.
Thank you.
Best regards.
Atte. Cristian N.
Configuration 1
Configuration 2
2 REPLIES 2
Sebastian_Eiche
Sebastian_Eiche
In the first view I would say, the contour looks the same, so maybe the dimension lines are not created. You set a checkbox for not combine them with other or 'everytime create a new' (sounds different but I could not remember the correct naming).
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
in reply to: Sebastian_Eiche
Hello
Thanks for your help.
Best regards.
Atte. Cristian N.
Hello
Best regards.
Atte. Cristian N.
