Solved by Sebastian_Eiche. Go to Solution.
In the first view I would say, the contour looks the same, so maybe the dimension lines are not created. You set a checkbox for not combine them with other or 'everytime create a new' (sounds different but I could not remember the correct naming).
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
