Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
CIS/2 Export - No properties on beams
4 REPLIES 4
1069 Views, 4 Replies
Hi All,
We have been trying to export our AS2019 model into stp file as requested by customer. The model is numbered. The export was succesfull, however when imported into Naviworks all beams were shown like cuboids.
After thais we attempted to create very simple model with two beams and 1 connections, tried to export it and import into Naviworks (with same cuboid result) and also import back into AS, where during the import the as asks us to specify what profile the beams are. It appears that the beams don't have any properties.
Please see the screenshots documenting the whole process step by step.
Simple 3D test modelSimple 3D test model
Pressed 'Export CIS/2 button and confirmed this dialogPressed 'Export CIS/2 button and confirmed this dialog
.STP imported into Naviswork.STP imported into Naviswork
Importing stp back into ASImporting stp back into AS
AS request a profile to be specifiedAS request a profile to be specified
Specified different beam to the originalSpecified different beam to the original
ResultResult
P1 - simple test model, 2x UB beams and connection
P2 - Export dialog after pressing @Anonymous to CIS/2' button
P3 - Exported STP imported into Navisworks
P4 - Import STP back into AS
P5 - Dialog jumps up and AS wants us to specify the profile for each of the two beams
P6 - Chosen random beam different to the original one
P7 - Result
Could anyone please advise what we are doing wrong? We haven't changed any setting in mapping. We have our database in our server so all our machine can access it, but import was tried in older version of AS2018 with local database and the result was exactly same. Going through Inventor or Autocad mechanical is not an option as our model is too big (exploded model 250Mb, IGES 1.2Gb)
We will be glad for any sugetions.
Thank you all in advance
Ondrej
4 REPLIES 4
Sebastian_Eiche
The problem is maybe the definitions of export. What is the exact file format which is needed?
Is it CIS/2 (which is very specific file format theme) or do you want STP/STEP? Please note, there's a big difference between the stp file from the CIS/2 export and the stp file which maybe come from Inventor.
I'm not sure if Navisworks really could open CIS/2 files, because this is as specific file format for steel detailling software (tekla and Advance steel for example).
But if you export a CIS/2 file and import this file again it should work correct.
I made some short tests and it work. here's a small video (I made no settings, so it looks not the best, but it show all parts correct): https://autode.sk/3acoIGB
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
in reply to: Sebastian_Eiche
Hi Sebastian, and thank you for your reply.
Our customer asked us for stp export but didn't specify for what software does he intend to use it.
We also thought that stp is something like iges. What would be the right way to export stp/step file from AS then?
Thank you
Sebastian_Eiche
if you want to export step (which have the file extension *.stp, too) this is only possible by using 3rd part tools. Advance Steel could export *.sat files. Therefore you need the following steps:
  • create a copy of your model
  • in this copied model, delete all parts which are not necessary. like: connection boxes, modelviews, weldings..so all elements which could not be transfered to an 3D solid
  • then select the part you want to export (or select all for exporting the whole model) and the right mouse button and in the context menu you will find "explode to acis". you could also use the AutoCAD "explode command"
  • now you have solids and could export them with the normal export command and use the file extension .sat
The Autodesk knowledge is maybe a little bit short in this case: AKN
Sebastian Eiche
Great,
thank you very much for the advice.
Ondrej
