BOM on drawing - Item No.
SHDetailDesign
Message 1 of 9
SHDetailDesign
A client has insisted that i have an item no. next to each line on an assembly drawing BOM, as attached. I've tried numerous tutorials but can't get it to work, any help would be appreciated.
Thanks.
Replies (8)
Message 2 of 9
Karsten_Bork
what kind of number does the customer want to have on the list? The main part number or part number? Because an item number is not defined in the AS parts. You can write it by hand as commodity number...
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Karsten Bork
Mensch und Maschine acadGraph GmbH
Message 3 of 9
SHDetailDesign
As you note, they want something which is not available within AS but i read somewhere about using a formula?
Message 4 of 9
Karsten_Bork
o.k., i understand, It should just be a consecutive number. In my opinion this is not possible in BOM on drawings. Normally you can use a formula but you need a start value and there is no option for this.
Karsten Bork
Message 5 of 9
acbsdesign
The closest that I have is an Autocad table with one column, and formula next row to be top row +1.
Height of the rows will be easy to match the BOM. One table with lets say 12 rows to be always inserted in the prototype, deleting of  extra rows is quick, adding of extra rows is slower, but not that slow. Dragging the grip of the  row above will add the formula to the new rows.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 6 of 9
SHDetailDesign
Thanks for this i'll give it a go.
Stephen
Message 7 of 9
acbsdesign
@SHDetailDesign
Probably even a faster way to do this is adding an empty box next to the first column on the left, next to Part Marks, and another one that would be always empty next to MP, and one added to the BOM Header, with text "Item No."
This way boxes will be always aligned in BOM.
Next-we can use one already done BOM on real dwg and fill the empty boxes with the numbers, max allowed in the prototype.
Next-we can copy the numbers with base point to the used prototype.
The only time we will waste modifying BOM on dwgs will be deleting the extra numbers, one select and one delete.
I was asked the same thing by a fabricator, I will do it too.
Ilko Dimitrov
ACBS
Message 8 of 9
SHDetailDesign
Thank you, i think i'll use this process.
Stephen
Message 9 of 9
suesLPLV6
Just utilized this suggestion to customize our BOM.  Thank you!
