Channel in wrong position for a double angle clip connection
We are trying to connect a channel to the side of a wide flange using the double angle clip connection.  However, the channel is offset to the outside of the two clip angles instead of the inside.  Is there a way to move it to the center?
joseph_hermogenes_042016
Have you tried using any default saved connections under library that works and just updating the connections?
