Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
BOM holes
7 REPLIES 7
Message 1 of 8
GHASEM_ARIYANI
539 Views, 7 Replies
BOM holes
GHASEM_ARIYANI
hi
How can we calculate BOM holes ?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
BOM holes
hi
7 REPLIES 7
Message 2 of 8
Buxtehude1963
if you mean how you can calculate the number of holes for every single part, you can use the token number holes in your bom. You can use this token for example in beam cut bill.
Regards
Regards
Message 3 of 8
GHASEM_ARIYANI
Hello
For example, I've used in projects of different types of holes, (At Bolts, Anchors and ...) .Now I want to know how many and what types of hole is used in
the project.
Hello
the project.
Message 4 of 8
Buxtehude1963
hi,
I had a similar problem and I solved using user attributes. For example insert number of slots in the user attribute 1, punch mark in user attribute 2. This involves a lot more work but I do not know if there is a possibility to do it in an automated way.
regards
hi,
regards
Message 5 of 8
GHASEM_ARIYANI
Thank you so much .
This will require a long time. And because we do manually. Certainly is high percentage inadvertent error.
Thank you so much .
Message 6 of 8
ChristianBlei
I guess you could use the Advance API to create a tool to solve such tasks.
BR,
Christian Blei
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
BR,
Christian Blei
Christian Blei
christianblei.de
Message 7 of 8
GHASEM_ARIYANI
hi
Please explain and  If you have training in this regard  Requested to share.
hi
Message 8 of 8
ChristianBlei
I started working my way into the API. You can download the API with its documentation and training material from
http://knowledge.autodesk.com/support/advance-steel/downloads/caas/downloads/content/advance-steel-2...
I do not know if there are any training courses or classrooms for the API available.
Christian Blei
Christian Blei
christianblei.de
Christian Blei
Christian Blei
christianblei.de
