Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
BLOCK INFORMATON MISSING
13 REPLIES 13
Message 1 of 14
stevenD3ZZG
626 Views, 13 Replies
Afternoon all,
Looking for a bit of help with the project information on my general assembly's. Whenever I fill out the project info in the 3D model, it doesn't transfer to the GA's, but if I open the block up to see the attributes it shows the info, just doesn't display it. Any info would be greatly appreciated.
pic attached.
13 REPLIES 13
Message 2 of 14
acbsdesign
in reply to: stevenD3ZZG
@stevenD3ZZG
After modifying the project settings, update defaults:
and then Update Page Header
If the used prototype is OK, then it should work.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 3 of 14
looks like block in block...maybe the hypersteelapageheader is integrated in the hypersteelpageframe?
I would open the prototype, explode the blockes and recreate them (Hypersteelpageheader + Hypersteelpageframe)
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 4 of 14
stevenD3ZZG
I've tried updating the defaults, and the page header, it didn't seem to do anything.
Sebastian, it's the same block used throughout the company, and it works everywhere else. Not sure why that would be?
Thanks guys
Message 5 of 14
only on your pc? if the model is open on another pc the page header could be updated?
Sebastian Eiche
Message 6 of 14
Yeah that's right. All others can update automatically with project info. It's just me that can't, although as seen in the picture I posted, the information is there, it just doesn't show on screen or print.
Message 7 of 14
maybe a graphic issue? could you please deactivate the hardware acceleration?
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-e...
And then "regenall".
Sebastian Eiche
Message 8 of 14
stevenD3ZZG
Done that now, it made no difference I'm afraid.
Message 9 of 14
Check your prototype.  You may have a layer turned off.
Message 10 of 14
stevenD3ZZG
All layers are on in the prototype.
Message 11 of 14
original prototypes are working?
Sebastian Eiche
Message 12 of 14
stevenD3ZZG
you mean autodesks default prototypes?
Message 13 of 14
yes this is what I mean
Sebastian Eiche
Message 14 of 14
stevenD3ZZG
I'm having the same issue with them. I have just managed to change all the text settings for each attribute and they are now appearing as they should, but the prompts don't appear with them. I will attach a picture to help explain what I mean.
