Bevel All Around on Square HSS
rmcintosh
rmcintosh
I am new to Advance Steel and I am trying to develop an assembly using square HSS and flat plate which will be output to a cnc machine (via NC1 file).
I need to apply a 45 degree bevel to the end of the HSS member.  This bevel will be all around (straight edges and the radius corner).  I am able to apply the bevel cut to the straight edges, but the bevel cut on the corners appears to be inverted.
Any advice would be appreciated.
Thanks.
Could you post a screen shot to see what the issue is?
Jonathan.Jasinski
You have to be very careful of exactly what you select when you apply the bevel feature.  I was able to get it to work like you described, but I was very careful to pick the line of the outer contour all the way around the tubing.Capture.PNGCapture.PNG
