Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Bent Grating
3 REPLIES 3
ecapati
435 Views, 3 Replies
Bent Grating
Capture.JPG Can this be done in AS? Is there a way to bend a grating?
3 REPLIES 3
ArjunGaba
in reply to: ecapati
@ecapati  it is not possible directly but you can create a user section to achieve it..
ecapati
in reply to: ArjunGaba
I tried to use  a u-bent plate but i cant get the "Flatten expanded metal" hatch to it, so that didn't work. I am assuming if I create a user section, that will be the same as using a u-bent plate?. I also tried the variable gratting to get he "flattened expanded metal" hatch, but i could find a way to u-bend a variable grating on AS. Any more ideas that you think will work?
ArjunGaba
@ecapati  for bom description better way is to go with user section sorry to say hatch is not feasible you have to show it manually in drawing ..
