objects are placing themselves on whatever layer is current and ot defaulting to "plates" or "beams" etc. how do i fix this?
Solved by lk. Go to Solution.
Hi Kirk,
I suspect you are using an Advance Steel template (DWT file) from a previous release which does not contain a specific layer for Anchor bolts like shown in the image below:
So maybe just try to add a "New layer" in the layer manager and give it the name of "Anchor bolts".
(FYI - the layer name in the layer manager must be the same name than the one assigned to the Default "Anchor layer" in the Management Tools)
Regards
Philippe
Hello Kirk
Open the (ASTM) Advance Steel Management Tools >Table Editor> Open the (AS) ODBC icon and expand the AstorSettings by selecting the expansion arrow.
This stems from your AstorSettings. Scroll to Default_STR. This is the current AstorSettings which reflects changes made to the Astor settings. Default_STR_AdvanceSteel, and Default_STR_original which is the out of the box settings for Advance Steel.
C407_LayerName is the key and the layer name “Anchor bolts” is in the Value column.
This name, Anchor bolts, should appear in the Layer management. While in Advance steel type la at the command line then hit the enter key to bring up the Layer manager.
Create a new layer called Anchor bolts. It should have the same spelling as depicted in the AstorSettings. Make sure the Standard layer is the default. Now when you add anchors they will be created on the correct layer.
I hope this helps.
Best Regards,
Janet
Graitec Montreal,Canada
