I have tried to filter "corner cuts" of the beams with "beam features" filter. It seems that it doesn't work in AS2016. Do you have the same issue?
Is there any way to filter this type of cuts?
I think the same issue is with "bevel cuts", there is no way to filter those kind of features.
theese are not corner cuts on the beam... Try with plate features filter :D...
Unforunatelly those are flat bars not plates and the filter "plate features" doesn't work too,
Hi Leszek,
You might try in this way:
- select one corner edge feature
- right-click and choose the option Select similar
As result, all these specific features (beam corner cuts) will be selected.
Best regards,
Emy
