Hi, all.
I tried to detail Beam with connected columns. However, some columns are not displayed in Detail Drawing.
It happens randomly. Do you have any idea why it happens?
Solved by johnjmbennett. Go to Solution.
I found missing objects are main parts of assemblies.
Why Main part of environments are not shown in Assembly Drawings?
You can see all blue marked main parts are not shown in Detail Drawing.
It is Advance Steel 2020.
can’t quite see all your settings , but found this old FAQ over this subject, may help:
https://www.graitec.com/faq-item/faq-2168-how-are-environment-elements-on-a-worksho/
seem to recall having similar issue a while back, think we had not defined the extra elements in the system.
John Bennett
Thank you, John.
It passed more than 6 years since we met in person.
This is key point.
