Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Base plate to other beam end?
6 REPLIES 6
haedicu
2883 Views, 6 Replies
I'd like to use the base plate joint on a rafter. How can i switch it to the other beam end?
There is a checkbox inside the connection dialog on baseplate layout tab, where you can easily decide, to which beam side the joint should refer.
6 REPLIES 6
muleman1
in reply to: haedicu
Have you tried the 'end plate' tool
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
marceuheinzmann
in reply to: muleman1
  I need to create a Steel Joists for my roof, like this image:roof.jpg
How do I create automatically this?
Thanks.
muleman1
in reply to: marceuheinzmann
I created the attached truss in a couple minutes using the truss button, located on the home tab in the extended modeling tab. Play with it a little, I think you will find it simple to use. For practice start with a new blank drawing, when the the truss macro starts, choose 0,0,0 as the starting point and make the length in the Y or X direction of your choice. Once you create the basic truss, you can see the effect of changing values in the various tabs of the create truss macro.... I hope this helps
dirvine_behlen_ca
Consider using the "Gable wall end plate" joint in the connection vault. It sounds to me like this is what you want. You can also (optionally) specify stiffeners at the middle or flanges with this connection.
Try using the cajoint tool. And also what windows does your computer run on??
Peace. Give a kudo if you cool!!!
use the cajoint tool
