I'd like to use the base plate joint on a rafter. How can i switch it to the other beam end?
There is a checkbox inside the connection dialog on baseplate layout tab, where you can easily decide, to which beam side the joint should refer.
I need to create a Steel Joists for my roof, like this image:
How do I create automatically this?
Thanks.
I created the attached truss in a couple minutes using the truss button, located on the home tab in the extended modeling tab. Play with it a little, I think you will find it simple to use. For practice start with a new blank drawing, when the the truss macro starts, choose 0,0,0 as the starting point and make the length in the Y or X direction of your choice. Once you create the basic truss, you can see the effect of changing values in the various tabs of the create truss macro.... I hope this helps
Try using the cajoint tool. And also what windows does your computer run on??
Peace. Give a kudo if you cool!!!
