Currently Advance Steel is converting my plates to flats (as I believe it is meant to do).
What I would like Advance Steel to do is find all my GR250 plate that exist as a flat size, to GR300 flats on my fab detail drawings. And keep all my GR350 plate as they are (and if possible, label them 'WidthxLengthxThickness PL').
Is this possible? And further on would it stay the same on my BOM (assuming it would).
Thanks in advance!
Solved by Sebastian_Eiche. Go to Solution.
you should have a look here in the forum for the keyword "mapping".
One Example for bolts is here: https://help.autodesk.com/view/ADSTPR/2021/ENU/?guid=GUID-6E8438FA-3A7E-4072-9E17-E32EEF037C76
A very good article for understanding: https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/simplecontent/content/advanc...
and for sure a small youtube video: https://www.youtube.com/watch?v=3_S83kgjiiQ&list=PLY-ggSrSwbZr_DW0ssM7B20FqEvhoCnjq&index=8
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
