Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
ASSEMBLY DRAWINGS WITH PARTS
1 REPLY 1
CSarris
513 Views, 1 Reply
I am trying to use the process drawings routine "All Assemblies w/parts - One per sheet", but I see that parts used in more than one assembly, appear as a part drawing detail only in the 1st assembly drawing that contains them.
Is it possible to have them in all the assembly drawings where they are included?
(Even if they appear in more than one drawings).
Thanks in advance
1 REPLY 1
johnjmbennett
in reply to: CSarris
You need in the management tool defaults to change the setting to allow for duplicate parts, with the setting checked you can run the same drawing file of an object multiple  times.
https://knowledge.autodesk.com/support/advance-steel/getting-started/caas/simplecontent/content/allo...
John Bennett
