Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Hiding axis lines for all drawings!
2 REPLIES 2
abdoullah_tomeh
783 Views, 2 Replies
Hello everybody,
I don't like the axes lines of the beams when generating drawings.
How to hide it automatically.
I know that I can select similar and hide it but I want it to be automatic.
2 REPLIES 2
Presume you mean the system line ,  to change this you need to use an user style and then in each style you use, look for the presentation rule , change it to one that does not have ‘system’ in the name.
visiblesystem to visible as an example.
but be careful as drawing style changes can have knock on affect to the dimensions rules.
 Best to back up the astoraddin Database before making any changes, as it can be easier to swap this out afterwards, if something gets messed up
John Bennett
Hi John,
I tried to
do that and changing label for main part but it showed assembly number instead of single part
