Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
AS21 - How to display dimensions in 3D Model View?
1 REPLY 1
fila-r
495 Views, 1 Reply
Is there a way to show/visualise measurments of parts and distances in the model view? Its really annoying having to go between models and drawings when you have a lot of them.
An example of this is adding purlins that have to be a different distances from a specfic point, then jumping between the drawing and model to make sure the dimensions are right.
Labels (1)
1 REPLY 1
in reply to: fila-r
-Set UCS along the area you want to measure (along the rafter to measure the distance between purlins using your example)
-Type out the command 'measuregeom' and hit enter
-Select 'distance'
-Select either end of the purlins to measure the distance between them.
Measurements between the 2 points will show in the dialogue box as an X/Y and Z distance along the set UCS.
