I'm looking for a Connection in the Vault, yet dont seem to find the one I'm looking for.
I got 2 RHS200x200x4 (Metric) connected to either side of the web of a IPE550 and I want to set up a 'Moment End Plate' for both, but if I do both individual, their bolts clash with eachother.
I did see 'Double sided end plate' as a connection, but that doesnt have the galvanising holes that I would need to apply here.
Can anyone direct me to the right connection?
If nothing else work, I was just thinking of setting both ends up with an 'End Plate' Connection, since this also has the galvanising holes worked into it, and applying the bolts manually, but if I dont have to, I would prefer not to.
Solved by AleckGiles. Go to Solution.
You would be better off using the Double Sided End Plate (with safety bolt() connection. The two end plates then share the same bolts and you don't need to explode the joint to add manual galvanising holes. The End Plate joint on the "plates at Beam" page of Connection Vault has all sorts of issues without the galv holes moving and not being correct when you adjust the beam. Much less work to add one joint and 2 galv holes than add two joints plus several bolts.
Aleck Giles, Structures Consultant, Graitec
Yeah i figured as much, thats what i had to resort to eventually wich seemed the less painfull way.
It becomes even easier to just make a bolt connection between the 2 plates and then change the bolt connection to just holes, saves the trouble of puting holes on both plates.
