Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
AS 2022 freezes when zooming to special part realistic view
4 REPLIES 4
s_hannemann
255 Views, 4 Replies
s_hannemann
Hello there,
anyone encounter the same bug or feature that AS 2022 just freezes if u zoom in closely to a special part in realitic view? I attach the special part where it happens always. Any advice or workaround?
Maybe its just me and some update is missing. I have the following german version.
Hello there,
4 REPLIES 4
Sebastian_Eiche
by opening the dwg, there's the dialog for showing proxys...how is the dwg created?
I mean there're about 800 3D solids in it, with a lot of exact contours.
After exploding the solids to "areas" it's a bit better.
Maybe it's a better way to use it as XREF?
And additional I copy the object in a new DWG and insert this as specialpart..work better too
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
s_hannemann
thanks for the quick reply. The special part was modeled in inventor.
I exported it as STEP, imported the STEP in AS, exploded all Blocks into 3D-Solids.
The problem is, i cant explode it any further because i need drawings. If the contours are areas, AS wont show them in the drawing. In addition, i have special drawing styles, where i swap between showing special parts and not showing them. Thats why i dont want to use xrefs either. Didnt found a way to create drawing styles bound to cameras which show xrefs.
It would look like that.
Can u zoom freely in the Special Part without AS freezing?
Sebastian_Eiche
if you use areas instead of solilds these will also be shown in drawings when using as the specialparts.
Problem will be: the contruction is not free of clashes I think.
zoom with solids:
https://autode.sk/3uHGPiM
Sebastian Eiche
zoom with solids:
Sebastian Eiche
s_hannemann
i tested it. Left is the special part with areas and regions, right is with 3D-solids. The difference is huge.
AS has its problems with round contours. U can have 3000 plates and beams in a single model without problems, but 1 circular object and AS just dies...
Anyway your screencast shows me that the problem is on my end, probably my hardware. If i swap the graphic performance to middle mode it wont freeze anymore. Could have tested this earlier i guess...
Thanks for the quick help.
