Could somebody explain me a reason that it is not possible to manually label anchors and studs.
Yes... I know that it could be done via "Drawing Styles", but sometimes I need to manually label few anchors or studs and it can't be done on the drawing.
I can label bolts and holes but can't do it for anchors and studs!
JerzyCP
Solved by produkcja. Go to Solution.
Do the following steps. I don't know why there is no specific row for anchors but when you add the anchor name token in place in screenshot below it works fine.
Regards
Przemysław
I forgot to mention those have to be ticked to make it work.
Press "label content magager" I guess it's called that way in English, then select an anchor and tick boxes I showed below.
Also make sure you use user settings while labelling.
In MT, filter 'Token', uncheck 'Take from model only required tokens'.
=> Update defaults
Regards.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
@acbsdesign wrote:Hi,
=> Update defaults
Regards.
@acbdesign - checked it twice (checked and unchecked)... and it is not working in Polish language AS installation.
In English version it is working without any problems, but unfortunately - for some reasons - I had to work in Polish version of AS.
@produkcja- after "Menadżer zawartości etykiet" ("Label content manager"), a message is displayed: "Wszystkie odsyłacze już istnieją w detalu" ("All tokens already exist in detail").
OK - finally it is working:
1. In English version of AS - always worked without any problems.
2. In Polish version of AS - it is working only if label is changed by @produkcja procedure. Important was to set active "User settings" (latest picture).
Anyway... I have no idea why it is so complicated in Polish version, because in English version there are no problems with labelling anchors, studs or special parts !?
