Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Anchors and Studs - labelling
6 REPLIES 6
legar
587 Views, 6 Replies
Could somebody explain me a reason that it is not possible to manually label anchors and studs.
Yes... I know that it could be done via "Drawing Styles", but sometimes I need to manually label few anchors or studs and it can't be done on the drawing.
I can label bolts and holes but can't do it for anchors and studs!
JerzyCP
6 REPLIES 6
produkcja
in reply to: legar
Do the following steps. I don't know why there is no specific row for anchors but when you add the anchor name token in place in screenshot below it works fine.
Regards
Przemysław
legar
in reply to: produkcja
For me it is not working ☹️...
produkcja
in reply to: legar
I forgot to mention those have to be ticked to make it work.
Press "label content magager" I guess it's called that way in English, then select an anchor and tick boxes I showed below.
Also make sure you use user settings while labelling.
acbsdesign
in reply to: legar
In MT, filter 'Token', uncheck 'Take from model only required tokens'.
=> Update defaults
Regards.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
legar
in reply to: acbsdesign
=> Update defaults
Regards.
@acbdesign - checked it twice (checked and unchecked)... and it is not working in Polish language AS installation.
In English version it is working without any problems, but unfortunately - for some reasons - I had to work in Polish version of AS.
@produkcja- after "Menadżer zawartości etykiet" ("Label content manager"), a message is displayed: "Wszystkie odsyłacze już istnieją w detalu" ("All tokens already exist in detail").
legar
in reply to: legar
OK - finally it is working:
1. In English version of AS - always worked without any problems.
2. In Polish version of AS - it is working only if label is changed by @produkcja procedure. Important was to set active "User settings" (latest picture).
Anyway... I have no idea why it is so complicated in Polish version, because in English version there are no problems with labelling anchors, studs or special parts !?
