How to change the Advanced Steel NC file format?
We have a CNC machine that drills holes in Equal and UnEqual Angles.
It can read in NC files (or NC1 files) but Advanced Steel does not seem to create the right format.
The NC file created from Advanced Steel doesn't look anything like what is required?
Can the format be changed to what is required?
This is an export from the hole drilling machine.
This is the format required.
Solved by johnjmbennett. Go to Solution.
We need the 3D feature of NC files.
With dxf the machine will not know which leg of the angle member to put the hole in.
This is how the code looks from Advanced Steel
John Bennett
John Bennett
John Bennett
John Bennett
Hi. My company is very new with Advance Steel and I'm having problems reading the nc code that was generated using Advanced Steel and wondering if we can modify the Advance Steel code similar to the current code we are generating using Striker Systems. I'm sure you already answered this question for FProcp but i'm not following.
Advance Steel:
ST
001
6001000316
6001000316
A992
7
B 1.9
B
2936.87
357.04
0.00
0.00
1.88
0.00
5.31
0.73
0.00
0.00
0.00
0.00
BO
v 11.13u 140.42 11.11 0.00l 11.11 0.00 0.00
v 11.13u 216.62 11.11 0.00l 11.11 0.00 0.00
v 2914.63u 140.42 11.11 0.00l 11.11 0.00 0.00
v 2914.63u 216.62 11.11 0.00l 11.11 0.00 0.00
SI
v 2.00u 2.00 0.00 10r6001000316
AK
v 0.00u 0.00 0.00
v 2936.87u 0.00 0.00
v 2936.87u 265.40 0.00
v 2847.97u 265.40 0.00
v 2847.97u 357.04 0.00
v 88.90u 357.04 0.00
v 88.90u 265.40 0.00
v 0.00u 265.40 0.00
v 0.00u 0.00 0.00
PR
+ 76.79 2.90 2.90
+ 73.89 0.00 0.00
+ 2.90 0.00 2.90
+ 0.00 2.90 0.00
+ 0.00 19.41 0.00
+ 1.88 19.41 0.00
+ 1.88 2.90 -1.02
+ 2.90 1.88 0.00
+ 73.89 1.88 -1.02
+ 74.91 2.90 0.00
+ 74.90 175.49 -1.02
+ 73.89 176.51 0.00
+ 2.90 176.51 -1.02
+ 1.88 175.49 0.00
+ 1.88 158.98 0.00
+ 0.00 158.98 0.00
+ 0.00 175.49 2.90
+ 2.90 178.39 0.00
+ 73.89 178.39 2.90
+ 76.78 175.49 0.00
+ 76.79 2.90 2.90
KA
88.90 339.35 2847.97 339.35 -90.00 1.02
88.90 265.99 2847.97 265.99 -90.00 1.02
0.00 91.04 2936.87 91.04 -90.00 1.02
0.00 17.69 2936.87 17.69 -90.00 1.02
EN
Striker System (our current programming software):
:7421(60010003-REL-CLE-011705)
(WH 13-46-85)
MAT/B4H0.047X116.25Y14.0
X59.875Y4.75T12
X56.375
X58.125Y6.25
Y7.75
X0.75Y0.75T1C0
X2.5
Y2.625
X0.75
X0.938Y5.5T3
Y8.5
X60M03
REP/DX19
X115.312
Y5.5
X115.5Y0.75T1C0
X113.75
Y2.625
X115.5
X98.425+19Y60.039M03
FRM/X98.425
X98.425Y60.039M30
please let me know if there is any additional information you may need. thank you so much for your time!
have a great day
Advance Steel:
ST
001
6001000316
6001000316
A992
7
B 1.9
B
2936.87
357.04
0.00
0.00
1.88
0.00
5.31
0.73
0.00
0.00
0.00
0.00
BO
SI
AK
v 0.00u 0.00 0.00
v 0.00u 265.40 0.00
v 0.00u 0.00 0.00
PR
+ 76.79 2.90 2.90
+ 73.89 0.00 0.00
+ 2.90 0.00 2.90
+ 0.00 2.90 0.00
+ 0.00 19.41 0.00
+ 1.88 19.41 0.00
+ 1.88 2.90 -1.02
+ 2.90 1.88 0.00
+ 73.89 1.88 -1.02
+ 74.91 2.90 0.00
+ 73.89 176.51 0.00
+ 2.90 176.51 -1.02
+ 1.88 175.49 0.00
+ 1.88 158.98 0.00
+ 0.00 158.98 0.00
+ 0.00 175.49 2.90
+ 2.90 178.39 0.00
+ 73.89 178.39 2.90
+ 76.78 175.49 0.00
+ 76.79 2.90 2.90
KA
EN
(WH 13-46-85)
X59.875Y4.75T12
X56.375
X58.125Y6.25
Y7.75
X0.75Y0.75T1C0
X2.5
Y2.625
X0.75
X0.938Y5.5T3
Y8.5
X60M03
REP/DX19
X115.312
Y5.5
X115.5Y0.75T1C0
X113.75
Y2.625
X115.5
FRM/X98.425
X98.425Y60.039M30
have a great day
