Hey guys,
I'm having a little issue with my assembly drawings the system line on all my drawings stay on the base of the drawings instead of the center of the beam, because of this my assembly drawings are detailing incorrectly. Is there a fix to this? I just started using advance steel and I'm having trouble with this step. I've attached photos as a reference.
Hey guys,
Solved by AleckGiles. Go to Solution.
You should always model with the System line in the significant point WITHIN your beam. I would not use the Y and Z offsets on the positioning tab of Advance Properties. Move the beam instead. The system line is used as the dimensioning datum in Part and Assembly drawings. You control the system line position relative to the beam so you control the datum.
Aleck Giles, Structures Consultant, Graitec
