I am trying to trim a gusset plate to rolled angles as shown below. I have tried advanced trim to even just one angle and I can't get it to work. I have tried WCS and USC at the plate face.
Does anyone have an idea on how to do this.? I had no problem trimming the angles to the end plates.
I am using Advance Steel 2019.
Solved by johnjmbennett. Go to Solution.
Try some of the opitons on the features palette,
Not sure if you are trying to trim the angle / split either side of what looks like vertical stiffener in the plate.
you may find you have to use a polygon contour, because the angle is curved.
John Bennett
John Bennett
Thanks for your help John.
I got it to work by adding the angle at the first instance and created an array for the remainder. I then individually trimmed the plate gusset at each angle. Then once all the trimming was complete I deleted all the angles and the trim contour remained. I then was able to polar array the remaining gussets all trimmed correctly. Lesson learned. You cannot trim to a rolled section.
