Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel doesnt work
4 REPLIES 4
bartbla378
317 Views, 4 Replies
Program open and i cant do nothing. i cant close i cant use i cant do nothing .
Tags (1)
4 REPLIES 4
JeromeK4432
in reply to: bartbla378
I have seen this before.
In my case the license activation window was hidden behind the main AutoCAD window.  If this is your case also, then try using ALT+Tab to switch windows and it should show you the license activation window to login and re-authorize your instance of Advanced Steel.   Maybe?
bartbla378
in reply to: JeromeK4432
thank you for trying to help but it dosent work on my computer 😞
JeromeK4432
I have also seen this when the databases in Advanced Steel are corrupted.  The only fix for that scenario  I have been able to get to work, is to uninstall and reinstall.  I hope it doesn't resort to that for you.
I might suggest that you create a support ticket with Autodesk.
Dias_Antonio
@bartbla378
This case seems to be a installing issue.
- No messages were displayed?
- Installation was succesful?
- Old installation that are causing a conflict?
Rename the old folder (Advance Steel 20XX to Advance Steel 20XX_OLD) and re-install everyting from zero
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
