Advance Steel 2021: Unhandled Delayload "cpprestsdk.dll" Module Not Found Exception at 8F7ECD29h when running add-on
sarai2SXHU
sarai2SXHU
Community Visitor
Community Visitor
I am using an internal add-on that connects a database (Access file) to work in advance steel. It worked until yesterday, when I received the next message: Unhandled Delayload "cpprestsdk.dll" Module Not Found Exception at 8F7ECD29h when running add-on
I've been looking for any information but I have' found nothing.
Thank you!
Sarai
Rude_H
Dear @sarai2SXHU
I do have the same fatal error in my AutoCAD 2021 and 2023, trying to export data to Access.
On the internet i find the following link which seems identical to the above problem.
It probably has to do with an update of Office 365.
Autoplant CE Update 2 on Autocad 2020: Fatal Error: Unhandled Delayload "cpprestsdk.dll" Module Not ...
Quote: "Resolution was to roll back Office 365 update (we rolled back to 16.0.8326.2062, which might have been excessive, but effective)."
Hope this will help.
sarai_cortajarena
Observer
Observer
It worked rolling it back! Thank you!!
ncsn
We had the same problem with our own proprietary software. turned out it uses Microsoft's AccessDatabaseEngine; I uninstalled it and downloaded the one at the MS site, which is a bit newer, and a reinstall solved the problem.
Rude_H
When does Autodesk come with a Hotfix? Problem is still going on on all our systems...
ncsn
According to the guy who developed my company's add-on, the issue is with a newer version of the MS AccessDatabseEngine, so I think it's unlikely Autodesk will do anything about it. As I wrote above, our problem was resolved by installing the latest version from the MS site.
I was told by someone on another forum that they prefer the older version - 2010 - to the newer (2016), as it was much faster. We've never noticed any difference with our own add-on, and, anyway - if the choice is between working slower to not working at all, I know which one I'm choosing.
