Hello fellows,
I was wondering does anyone have experience in the IFC Export from Advance Steel into Strakon.
Are there certain thing which need to be prepared in order for this import to work?
Solved by Sebastian_Eiche. Go to Solution.
In Advance Steel there're many many settings, but not one for IFC 😉
So in your case, there should be nothing you could do.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thank you very much.. In term of IFC - this format as such is not really needed but we are experiencing problem when loading the DWG Files from Advance Steel into Strakon that the 3D geometry gets lost and there for many information.
I have no experience in advance steel therefor I have no idea what this problem could be. Any thoughts?
