I have a problem with the "Template", namely that all elements appear to me on layer 0, can someone help me with this, or can someone provide me with the "Template" from the German version of AS2021?
Best Regards
Solved by orasquier. Go to Solution.
Good morning,
Are you on the standard layer to model?
OK, on this model choose the standard slap and save the model in .dwt so that the change will be in the next drawings.
this should be the original
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
