Advance Steel 2021 GER Default Template
g_swiatek
g_swiatek
I have a problem with the "Template", namely that all elements appear to me on layer 0, can someone help me with this, or can someone provide me with the "Template" from the German version of AS2021?
Best Regards
orasquier
Good morning,
Are you on the standard layer to model?
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
g_swiatek
When I open the program, I am immediately on this layer, as in the picture below.
orasquier
OK, on this model choose the standard slap and save the model in .dwt so that the change will be in the next drawings.
g_swiatek
Okay, it works. Thank you very much.
orasquier
With pleasure 😉
Sebastian_Eiche
this should be the original
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
