Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel 2019 Embed Plate Connection Troubleshooting
2 REPLIES 2
591 Views, 2 Replies
Hello all,
I am trying to create an embed plate connection for a steel beam bearing on parallel concrete wall using "Embed Beam Seat" connection under 'Miscellaneous' tab of connection vault.
For some reason, the anchors that should stop at the beam bottom flange instead always stretch out all the way to the beam top flange - see attached image. Please advise on how to resolve this. Thanks!
2 REPLIES 2
Sebastian_Eiche
The distance if the anchors is not enough. They are too close the web and therefore the clamping length try to use the whole beam. You should set the distance between the anchors a bit higher
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
in reply to: Sebastian_Eiche
Thank you, Sebastian! The solution you suggested works!
Technology Administrators
