Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
adjusting welded beams, I Symmetric-length of plates
3 REPLIES 3
derrick_lambrecht
276 Views, 3 Replies
derrick_lambrecht
I have an I beam created as specified in the title, but the one side of the beam needs to be a little bit "taller" (the blue section shown in the snip below).
How can I make the plates taller and leave the radiused plates alone with the top pipe alone?
3 REPLIES 3
bigcarl5000kg
Hi @derrick_lambrecht
can you post here an DWG example please?
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
derrick_lambrecht
see attached as requested. I also need to shorten up a couple of the posts because of an elevation change as well
derrick_lambrecht
Any luck with looking into this yet by chance?
