Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Additional number added when creating drawings
21 REPLIES 21
Message 1 of 22
aaron_irvine1
917 Views, 21 Replies
aaron_irvine1
Hey guys,
I am numbering single parts at 1000 & assemblies at 100 both 'with drawing number' method. The problem I am getting is an additional number being added to the front of my SP and MP numbers, its doing my head in.
Any help please?
Aaron.
Hey guys,
Any help please?
Aaron.
21 REPLIES 21
Message 2 of 22
Flies-Eyes
in reply to: aaron_irvine1
Flies-Eyes
Screen shot might help.
Message 3 of 22
aaron_irvine1
in reply to: Flies-Eyes
aaron_irvine1
Sorry, as per below. There is an additional 1 added to my SP's and an extra 0 added to my assemblies.
Message 4 of 22
aaron_irvine1
Message 5 of 22
Flies-Eyes
Flies-Eyes
Ok, that helps a little.  Those are temporary place keepers due to using
post processing. Because no drawing has been created yet, it can't allocate the drawing number to the temporary place keeper.
Message 6 of 22
aaron_irvine1
aaron_irvine1
Ok, did you see the first two screen shots where I have created drawings for the single parts? For example I had parts numbered M1000 etc then once drawings were created (starting at number 1000) it changed my single part number to M11000.
Message 7 of 22
Flies-Eyes
Flies-Eyes
Sorry, didn't see this screen grab.
You will need to show me the numbering setup dialogue box. It looks to be a %parameter in you numbering string.
Message 8 of 22
aaron_irvine1
aaron_irvine1
Thank you.
Thank you.
Message 9 of 22
Flies-Eyes
Flies-Eyes
Remove the %counter parameter from the string.
Message 10 of 22
aaron_irvine1
aaron_irvine1
It wont allow me for some reason?
Message 11 of 22
Flies-Eyes
Flies-Eyes
In that case remove the %method number and change you Couter settings.
Personally, I go the other way and don't use the post processing but rather have the Part and Assemby number drive the drawing number.
Message 12 of 22
aaron_irvine1
aaron_irvine1
Thank you!
Could you just explain your method a little more? What do you mean when you say post processing?
Thank you!
Message 13 of 22
aaron_irvine1
aaron_irvine1
I just had the same issue removing the method number. Says it is required and I cant select OK button.
Message 14 of 22
Flies-Eyes
Flies-Eyes
What options do you get with the drop down counter box?
I noticed at the top you are not actually using post processing.
It seems your counter setting is driving this.
Message 15 of 22
aaron_irvine1
aaron_irvine1
Did you mean the format as below?
In the counter I just have the number or small / capital letters.
Message 16 of 22
Flies-Eyes
Flies-Eyes
Try these settings.
Try these settings.
Message 17 of 22
Ignus.E
Ignus.E
Just a question. Did this happen on initial drawing creation or did you perhaps create the drawings, deleted them at some stage, made some edits and recreated them? Also in the special tab of the numbering,  do you have the option on or off for reuse numbers...?
Message 18 of 22
aaron_irvine1
in reply to: Ignus.E
aaron_irvine1
Hi Ignus,
You are correct, I had created some drawings previously, continued modelling in the same model, deleted all drawings and numbering and started again. Have made a mess of it really...
I do have the 'reuse unused numbers' currently ticked.
Hi Ignus,
Message 19 of 22
Ignus.E
Ignus.E
Ok, this happened to me as well a few times. There's a specific way that you need to deal with changes when working with the "with drawing number method". There was an article on this but the link does not seem to work anymore. This method is good, but I have found it to be to easily to get in that problem that you are in now. Personally I like a different method that still ensures that the drawing number matches the part numbers. Have a look at this link in this forum: https://forums.autodesk.com/t5/advance-steel-forum/preferred-numbering-method/m-p/11612917#M51919 This method is what iwafb described in this chat.
Message 20 of 22
aaron_irvine1
aaron_irvine1
Thanks for the info Ignus, so this is the method you now use all the time?
I think starting from scratch with prototypes, BOM lists etc might be beyond me at the moment.
What are your thoughts on copying my model to a new drawing file and starting the process over again.
Problem I see is that I do need to continue modelling in the same project and still produce drawings as I go, so may end up in the same position..
Would deleting the drawings/numbering and then making the changes as per iwafb suggested be a good solution for me?
