I am trying to add to Rollover Tool Tips Dialog Box. I know the process, I cannot find the astxxxx. for the Main part mark and the Single part mark? Could someone help with this?
Thanks, Ed
Solved by johnjmbennett. Go to Solution.
See if this Blog post helps out :
https://graitec.com/uk/blog/rollover-tooltips-in-advance-steel/
John Bennett
Thank You, I know the procedure, I can not find the property for tag? for the Main part mark or the Single part park to
add to the dialog box.
Try ASTBEAM : then the part number should appear in the list:
same for plate:
John Bennett
