Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Adding to the Rollover Tool Tips Dialog Box
4 REPLIES 4
estewart3E8B6
378 Views, 4 Replies
I am trying to add to Rollover Tool Tips Dialog Box. I know the process, I cannot find the astxxxx. for the Main part mark and the Single part mark? Could someone help with this?
Thanks, Ed
4 REPLIES 4
See if this Blog post helps out :
https://graitec.com/uk/blog/rollover-tooltips-in-advance-steel/
John Bennett
Thank You, I know the procedure, I can not find the property for tag? for the Main part mark or the Single part park to
add to the dialog box.
Try ASTBEAM :   then the part number should appear in the list:
same for plate:
John Bennett
Thank You John, This worked, until I restarted. Now when I try the Same process this Does Not Work?
Any thoughts.
Ed
