I have a plate with a 1-1/4 dia. hole which needs an 1/8" chamfer @ 45 deg. The hole was created with the hole pattern feature. Is it possible to add a chamfer to hole edges in advance steel?
Under the hole , select the green hole feature, you may need to change the presentation of the plate to see this.
with the hole feature selected, then you can access its properties , and change the type from round to countersink or counter bore, there are several types.
changing the type allows you to define the counter sink features diameter, angle etc., under the properties tab.
link to AKN on hole types : https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
John Bennett
Hi there,
Change your hole to ‘Countersunk hole,’ then play around with parameters to get the figures you want.
Note: you will need to create holes in both sides of the plate.
