Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Allow more than 150 different values for assets custom attributes dropdown
We use assets custom attributes dropdown fields to ensure valid inputs parameters. Unfortunately there is currently a maximum of 150 different values and it is not possible to create more. As we work with large datasets (mainly model/component numbers), we would need this limit to be removed or raised.
2 Comments
buildintel
@Samuel_Mair Is the bespoke values available per Dropdown Type you say is capped at 150?
Why not use Text instead of Dropdown? Are you not uploading from a prexisting controlled database?
Samuel_Mair
@buildintel yes, the available values for dropdown are capped at 150
The available values come from a controlled database, but users have to set the specific value for the asset. Thus we need to make shure, that users only enter valid values, which are contained in the database. So free text isn't really an option.
