Users should be able to utilize Issue Templates when creating an issue from a clash.
We are utilizing custom fields and specific groups of watchers for different areas in a project and want an easy way to apply these values to clashes as we create them without having to fill them in manually for each clash.
I created Issue templates for each area assuming I would be able to utilize them when we created clashes only to find out that they do not apply. 😞
I could see this working as follows:
Method One:
- User selects Create Issue.
- User places pin.
- First selection in the properties window allows you to select and apply template properties to the clash.
Method Two:
- User places pin.
- A small window appears that allows you to select a template (or none).
- Properties window appears.
