unable to get data - Autodesk Data Connector for Power BI
yosevel_lyhardo
yosevel_lyhardo
Community Visitor
Community Visitor
Hi community,
I am trying to get data to PowerBI from Autodesk with my ACC account.
However, when I try to connect the data in PowerBi I get this error:
"There has been error in listing the projects and files in this HUB"
have anyone had this problem before?
Can you help me with this??
bert_c_VPKGC
Hi, I never had this error.
- Did you check the extraction on ACC was successful? If so, maybe you can download it and see if you can connect to the local csv-files ...
- Did you try to make a connection to your ACC-platform via one of the templates you can download from ACC? Just to see if that works.
Beside that maybe provide some extra info on how the ACC-hub and project(s) are setup. I am thinking about a specific naming of projects or folders ...
handjonathan
Hi @yosevel_lyhardo
Thanks a lot for posting your question to the forums!   Has the solution suggested by @bert_c_VPKGC  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
