Project template missing the DOCS module
abUXNMQ
Message 1 of 11
abUXNMQ
I have created a new project template from scratch and the module DOCS is not showing/missing.
I have assigned product and permissions to members, both Docs and Build.
Where did I go wrong or is there something I have to activate in addition to the product and permissions?
I hope sombody can help me quickly with this issue.
Best Regards
Anne
Replies (10)
Message 2 of 11
andr3sant0s
Hi @abUXNMQ
I replicated your process and the same thing happened!
For the Project Admin activate all Product access and refresh the page. In my case it solved the problem. After that you can disable Product access for the products that you don't want.
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
Message 3 of 11
abUXNMQ
Thank you for the quick reply. I changed the setup as you suggested, but unfortunately it did not solve the problem on my part.
Do you have any other suggestions for problem solving?
BR Anne
Message 4 of 11
andr3sant0s
Did you refresh the page after activating all Product access?
It's seams like a bug to me, so no straightforward solution.
Message 5 of 11
abUXNMQ
Yes, and I tried it twice, just to make sure
Message 6 of 11
andr3sant0s
@abUXNMQ
Sometimes it takes some tries to get it to work.
I noticed that changing a member from project admin to project member can also help.
Has I said, this seems to be a bug and with no direct solution.
Message 7 of 11
abUXNMQ
Thank you so much for your help.
This solved my problem!
BR Anne
Message 8 of 11
caic.wds
Hi, I'm facing the same issue here. None of the solutions work for me. Has there been any news on this topic? several projects showing the same issue.
Message 9 of 11
Susana_Duarte_LMSI
Same problem and none of the solutions is working. The video above cleary shows it's a bug. Why is Autodesk not addressing this 1 year later?
Message 10 of 11
RSomppi
How do you know that they aren't working on it?
Message 11 of 11
Susana_Duarte_LMSI
Actually, in my case the problem was that I was not looking in the right place. There is member of the project and members that can "edit" the template. We need to activate docs in the second one that we access by going to settings and permitions... I had to book and helpdesk apointment and only end up finding the solution before the meeting by viewing an hour long tutorial on Bridge...
I closed the ticket and told Autodesk that it's completely stupid to have the Doc's moduled closed by default. They told me to put my ideia in their ideia forum... when this is a correction they should correct quietly and internally...
Anyway, thank you for the message. This way I was able to update this thread with just another not so obvious solution, for any other struggling user out there.
