Members in Project Template not added to new projects created
brucegund
Message 1 of 11
brucegund
Creating a new project in ACC. Using a project template. This project template has worked for the past year. No problems. In this project template are all the members that need to be invited to a newly created project. Went to create a new project today using the same project template that has been working for over a year now and the members from the template were not added. I have to spend time adding all these members. I have to create 3 projects today, so that means having to invite all these members in each project. Why? Has something changed? Please fix!!!
Thank,
Bruce
Ps. nice to see there is a forum for ACC now.....
Replies (10)
Message 2 of 11
brucegund
Second day.... Still unable to create a project with a project template with assigned members not added to the newly created project. I guess I will put in a case to get it fixed.....
Message 3 of 11
ChitnisPrateek
Hi @brucegund I have tested this on my end as well, it looks like putting a ticket to Autodesk is your best bet. Thank you.
Thank you.
Prateek Chitnis
BIM Manager | AECO (Buildings)
Did you find this post helpful? Feel free to click on the Like button.
Message 4 of 11
brucegund
When you say test on your end, are you seeing the same issue, or is it working on your end?
thanks
bruce
Message 5 of 11
ChitnisPrateek
I am seeing the same issue.
Thank you.
Prateek Chitnis
Message 6 of 11
brucegund
From case so far....
Adding 10 members from a template can take up to 7 minutes. I have been aware of the wait and typically give it an hour to complete. These past projects have taken longer.
I will provide my team notice that once a project is created it can take 24 hours till work can start since we do not know when they will be given access. Unacceptable. Please fix.
Bruce
Message 7 of 11
Ryan_Holland_LDP
Hi @brucegund, just to confirm this seems to be working now on my end. There is a delay however of around 10 minutes before access is granted which could do with being quicker.
Message 8 of 11
PetrKazik
Same issue, members has to be added manually, should be fixed asap
Message 9 of 11
PetrKazik
members didn't show up ever, project was created weeks ago, nothing
Message 10 of 11
GallowayUS_com_RonAllen1
@brucegund - are you assigning members directly or using Roles? I haven't seen any issues with our Roles typically assigned around disciplines.
Ron Allen
Galloway BIM
Message 11 of 11
Jan_Partsch_PFHJQX7V7FQ8
... (reply reposted in another thread _ sry)
- post to be deleted by admins
