I have seen this question come up a few times and wanted to post a quick tip. In A360 you can create a project, add custom Avatar for the Project Image, and change the type of project it is. In this tip, lets look at how we create and then edit the project name.
Once the project is created, you have some options at the Project level.
Follow - Allows you to follow the project
PIn - Allows you to pin the project so it shows up under pinned projects.
NOTE: Projects are pinned by default, so once complete, you can unpin the project by clicking on the icon.
Archive and Delete - First option is to archive the project in case you need to get to it later, and if not, then you can delete the project. This shows up in the Archive section.
Transfer - This will allow you to transfer the project between hubs.
Now lets take a look at renaming your project. Click on the project to open it and then mouse over the Project name.
TIP: Rename shows up when you mouse over the Project name.
Now click in the Project name and start typing your new name. Click out of the field and and the new name is saved automatically.
You can change this name at any time, just follow the steps above.
Feel free to let us know if you have any questions about A360 and renaming projects.
