Message 1 of 17
HELP: The difference between A360 Drive and A360, BIM360 & Fusion Team
- Mute
- Permalink
- Report
The difference between A360 Drive and A360 Team, BIM360 Team & Fusion Team:
A360 Drive:
- Available as either Free 5GB, or 25GB if you’re a named user on a subscription entitlement.
- There is no option to increase the size of your A360 Drive. 25GB is the maximum per individual.
- A Folders based sharing solution. (i.e. create a folder, add files, then share with others)
- Privately at the folder level via email address.
- Publicly at the file level via public link.
- Connects to the A360 Desktop (allows “syncing” of local set of folders to online A360 Drive)
- A360 Desktop is only available as part of installation of AutoCAD based vertical products, or Inventor only.
- Is linked to A360 Team via the App Switcher.
- Can copy single / multiple files over into any A360 Team Project. (cannot copy folders)
- Files cannot be copied back over into your A360 Drive from an A360 Team hub. (have to download/upload)
- Contains similar viewer as A360 Team, allows zoom, pan, orbit, first person walkthrough, section analysis, explode, 2D measure, track versioning, download, and add comments
A360 Team, BIM360 Team, Fusion Team: (Same Product, just different branding)
- Commercially available collaboration solution, with two options.
- Free Personal hub = (1) Team Member, (1) Project, Unlimited Project Contributors, and 5GB in storage.
- A360, BIM360, Fusion Team hub = Unlimited Team Members, Projects, and Project Contributors.
- Storage is allocated at 500GB per Paid Team Member, which is pooled for all to use within the hub.
- Project (i.e. create a project, add folders and files, then invite others into the project)
- Two types of A360 Users that can be invited:
- Team Member – A user with access to the Team hub, can Create projects, browse Open projects and request to join Closed projects. (Secret projects are invite only for all users)
- Project Contributor – A user that could also be considered an external user. These users only have access to projects they are invited to.
- No Connection to A360 Desktop product (does not allow “syncing” of local set of folders to online A360 Drive)
- Is linked to A360 Drive via the App Switcher
- Single / multiple files can be copied from A360 Drive over into any A360 Team Project (cannot copy folders)
- Files cannot be copied back over into your A360 Drive from an A360 Team hub (have to download/upload)
- Contains similar viewer as A360 Drive, (includes all functionality listed for Drive Viewer) + Walk To Navigation, Markup, Live Review, and the Overview option
To get started with A360 go to a360.autodesk.com as well check out the below links.
- Getting Started with A360
- Basic Functionality within your A360 hub
- Advanced Functionality within your A360 hub
- Inviting Users into A360 Team
- Converting your A360 Team Trial into an Active Subscription
- A360 Blog: (see what’s new in A360)
Brett Wright
Brett Wright
